Pointer to struct for FlexCAN
Question asked by David XY Zhou on Feb 26, 2016
Latest reply on Mar 1, 2016 by David XY Zhou
volatile PMBox pTxMB= (PMBox)&(g_pCanReg->MB[TX_MB_num]);
while (1) {
   dwTxDLC = (dwTxDlen << CAN_CS_DLC_SHIFT);
   pTxMB->CS |= CAN_CS_CODE(CAN_TX_MSG_BUFFER_NOT_ACTIVE);
   pTxMB->WORD0 = dwData0++;
   pTxMB->WORD1 = htonl(dwData1++);
   pTxMB->CS |= (CAN_CS_CODE(CAN_MESSAGE_TRANSMIT_ONCE) | dwTxDLC);
   dwRTRBit = pTxMB->CS; // check for RTR bit
   if ((dwRTRBit & CAN_CS_RTR_MASK) == CAN_CS_RTR_MASK) {
      iRTRNotSetCount++;
  else if ((dwRTRBit & CAN_CS_CODE(CAN_TX_MSG_BUFFER_NOT_ACTIVE))== CAN_CS_CODE(CAN_TX_MSG_BUFFER_NOT_ACTIVE)) {
   //Version 1
   g_pCanReg->MB[TX_MB_num].CS &= ~(CAN_CS_CODE_MASK);
   g_pCanReg->MB[TX_MB_num].CS |= (CAN_CS_CODE(CAN_MESSAGE_TRANSMIT_RESPONED) | dwTxDLC);
   //Version 2
   //pTxMB->CS &= ~(CAN_CS_CODE_MASK); // Reset the code
   //pTxMB->CS |= (CAN_CS_CODE(CAN_MESSAGE_TRANSMIT_RESPONED) | dwTxDLC);
  //Version 3
   //pTxMB->CS = pTxMB->CS & ~(CAN_CS_CODE_MASK); // Reset the code
   //pTxMB->CS = pTxMB->CS | (CAN_CS_CODE(CAN_MESSAGE_TRANSMIT_RESPONED) | dwTxDLC);
iRTRSetCount++;
   // other code omitted ....
} //endof while
I tried three versions code as above. But only //version 1 works. I don't know why version2 and version 3 behave differently as version 1.
Thank you,
David Zhou
