SCI0SR1_RFRD set 0 before I read SCI0DRL'value
Question asked by 崇锐 卢 on Feb 24, 2016
UINT8
xReadCH376Data( void )  /* CH376读数据 */
INT8U ch;
    while(SCI0SR1_RDRF == 0) { /* Is the transmitter empty? */
    ch=SCI0DRL;
   return ch;
void Init_SCI0(INT16U sci_ytpe)
    #ifdef Enable_SCI_Interrupt
       //SCI0BD = BUS_CLOCK/16/BAUD; //设置SCI0波特率为9600
       SCI0CR1 = 0x00; //设置SCI0为正常模式,八位数据位,无奇偶校验
       SCI0CR2 = 0x2c; //允许接收和发送数据,允许接收中断功能
    #else
       SCI0CR1 = 0x00;
       SCI0SR2 = 0x80; /* Switch to the alternative register set */         //SCI使用发射器禁用接收器
       SCI0ASR1 = 0x83; /* Clear alternative status flags */
       SCI0ACR1 = 0x00;
       SCI0ACR2 = 0x00;
       SCI0SR2 = 0x00; /* Switch to the normal register set */
       (void) SCI0SR1; /* Reset interrupt request flags */
       //SCI0CR2 = 0x0C; /* Disable error interrupts */
//定义波特率115200
       SCI0CR2 |= (SCI0CR2_TE_MASK | SCI0CR2_RE_MASK);
    #endif
    switch(sci_ytpe)
      case InitBaud:
        SCI0BD = BUS_CLOCK/16/UART_INIT_BAUDRATE;
        break;
      case WorkBaud:
        SCI0BD = BUS_CLOCK/16/UART_WORK_BAUDRATE;
        break;
      default:
        break;
this is my code,
when I debug my program I found when a data is coming, RDRF register will be set 1,and SCI0DRL's value is correct.
But,when I clicked single step,
the RDRF reset,become 0
It makes me cant read what is coming in xReadData and code will be run in a dead loop.
