Multi core (multi thread vs multi processus) imx6dl
delauratfrançoi
Hello ,
My name is François I work with IMX6DL. I want to use the multi core.  I found several solutions:
     - Use the multi core with  the multi processus ( with the function shed_setaffinity)
     - Use the multi core with the multi thread (  with the function pthread_setaffinity_np)
What is the best solution?
PS : I saw also that we can use the libcpuset
Thanks for All Help.
François.
Labels (3)
jamesbone
Hello Delaurat,
Very good question, as usually happens with the engineering questions,  I think it depends on the end application, what are you trying to accomplish. I think this article can help
Thinking Parallel » Blog Archive More information on pthread_setaffinity_np and sched_setaffinity - ...
