User Defined Hash Key Generation.
pranavmadhu
I'm having an LS1021A-IOT rev2 board. I've fused wrong hash-key (It is not matching with the generated using cst tool) on to SRKHR0-SRKHR7 register by mistake. Is there a way to generate key hash according to the value read from the SRKHR registers?
Can anybody help me in solving these issue?
Thanking You in advance,
Pranav
bpe
The value stored in SRKHR is a hash of your public key, it is not the
key itself. If you lost the key, and know only it's hash, it is
practically not possible to reconstruct the key by definition of the
hash:
https://en.wikipedia.org/wiki/Cryptographic_hash_function
Furthermore, if you only have the public half of the key, there is no
known way to reconstruct the private half. That  is why RSA is secure:
https://en.wikipedia.org/wiki/RSA_%28cryptosystem%29
If, however, you do have the private and public keys that correspond
to your SRK hash, and they are valid RSA public and private key pair,
you can use them to sign and verify your boot images, just use the
appropriate key files.
Platon
bpe
hash:
Platon
