I downloaded the special edition Codewarrior V5.2 and saw that it does not support my micro-controller. I saw that the 5.1 version does but is only available for evaluation. Are any there downloads available that will allow me to use my controller in V5.2, or is the old version available anywhere. I am not going to spend a lot of money to get it. I'm a student and just using it for one semester for an embedded systems class. Thanks.
Solved! Go to Solution.
hi David,
the difference between CW5.1 special edition and evaluation edition is license.dat file.
CW5.1 special edition uses special edition license.dat
CW5.1 evaluation edition uses evaluation edition license.dat.
so if you want to use CW5.1 special edition, you can install CW5.1 evaluation edition from
CodeWarrior Legacy Downloads|NXP
the replace {your CW5.1 install}\license.dat with attached special edition license.dat
can this help you?
Jennie Zhang
Thanks to everyone for the replies. Your suggestions were very helpful.
Hello David
Please refer to the link below for how to download CW5.1 for HCS12:
https://community.freescale.com/thread/382638
Hope this helps!
Best Regards
Fiona Kuang
Technical Information & Commercial Support
Hi David,
In addition to Jennie ...
We've an University Program too.
Don't know if this could be interesting for you:
Pascal
NXP Technical Support
hi David,
can this help you?
Jennie Zhang
