Hi All,
I want to use CONFIG_RAMOOPS for taking crash log backup in to file system, I am using 3.0.35 kernel version and board is similar to IMX6 sabresd .
Some of the links i follwed:
https://www.kernel.org/doc/Documentation/ramoops.txt
Lindus Embedded / Using persistent storage to debug kernel crashes
http://stackoverflow.com/questions/28538091/using-persistant-storage-in-linux-kernel
https://www.kernel.org/doc/Documentation/ABI/testing/pstore Thanks & Regards,
Lavanya
Hello Bandaru, what kind of problems did you encounter by following the tutorials you mentioned?, can you give more details?
Hi SergioSolis ,
In my kernel menuconfig
CONFIG_PSTORE=y
CONFIG_PSTORE_CONSOLE=y
**CONFIG_PSTORE_FTRACE=y**
CONFIG_PSTORE_RAM=y
These things are not there if you have any patches for this can i get it ,
Thanks & Regards,
Lavanya
