How PBL identifies u-boot location in NOR flash from PBI commands?
Question asked by veerendranath jakkam on Feb 18, 2016
Latest reply on Feb 19, 2016 by ufedor
PBL identifies boot medium using config source switches then by default RCW starts at 0x0 of NOR flash.... but in NOR flash memory map u-boot is located in 0xEFF80000.
How PBL knows from where u-boot boot code(4kb code) starts for copying it to boot page?
Below is the RCW+PBI code in NOR flash of P2041RDB....
e8000000: aa55aa55 010e0100 4c580000 00000000  -> RCW preamble
e8000010: 58540000 00000000 648ea0c1 c3c02000
e8000020: de800000 40000000 00000000 00000000
e8000030: 00000000 d0030f07 00000000 00000000
e8000040: 00000000 00000000 091380c0 000009c4 -> PBI commands started at "e800004c"
e8000050: 09000010 00000000 091380c0 000009c4 -> Alternate config space high addr register setup
e8000060: 09000014 00000000 091380c0 000009c4 -> Alternate config space low addr registers setup
e8000070: 09000018 81d00000 091380c0 000009c4 -> Alternate config space attribute register setup
e8000080: 890b0050 00000002 091380c0 000009c4 -> Moving values to alternative config space, But here onwords I couldn't get exact meaning of PBI commands
e8000090: 890b0054 00000002 091380c0 000009c4 -> How PBL setting CPC SRAM as bootpage
e80000a0: 890b0058 00000002 091380c0 000009c4 -> How PBL knows from which location of NOR flash u-boot image should be copied to 4k bootpage space?
e80000b0: 890b005c 00000002 091380c0 000009c4
e80000c0: 890b0090 00000002 091380c0 000009c4
e80000d0: 890b0094 00000002 091380c0 000009c4
e80000e0: 890b0098 00000002 091380c0 000009c4
e80000f0: 890b009c 00000002 091380c0 000009c4
e8000100: 890b0108 00000012 091380c0 000009c4
e8000110: 89021008 0000f000 091380c0 000009c4
e8000120: 89021028 0000f000 091380c0 000009c4
e8000130: 89021048 0000f000 091380c0 000009c4
e8000140: 89021068 0000f000 091380c0 000009c4
e8000150: 09138000 00000000 08138040 d5e599a1 -> PBI command for CRC check
Thanks and Regards,
Veerendranath
