Steve,
The drivers that you see inside of the device folder for your K66 are specific to the SoC and do not contain any special core functionality. The systick is an ARM Cortex-M feature and all register information can be found in the core_cm4.h header file under the <install_dir>/CMSIS/Include folder. The register information for systick begins around line 735.
Jason
