After running "bitbake openjdk-7-jre" successfully, how do I install the resulting binary?
Question asked by nick caruso on Feb 18, 2016
Latest reply on Mar 2, 2016 by nick caruso
OK, I've found "rpm" files for openjdk in the tmp/deploy directory tree, but when I try to install them on my target machine using rpm, the following happens:
root@t4240rdb:~# rpm -i openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500.rpm
error: Failed dependencies:
    libc.so.6(GLIBC_2.3)(64bit) is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
    libc.so.6(GLIBC_2.4)(64bit) is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
    libc.so.6()(64bit) is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
    libz1 >= 1.2.8 is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
    libjli.so()(64bit) is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
    libc6 >= 2.20 is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
    openjdk-7-java is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
    openjdk-7-common is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
    update-alternatives-opkg is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
    libz.so.1()(64bit) is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
    libjli.so(SUNWprivate_1.1)(64bit) is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
    /bin/sh is needed by openjdk-7-jre-25b30+2.3.12-r5.1.ppc64e6500
There must be an easier way but I can't see it in the docs.
