Migration to SDK 2.x (KDS project (SDK 1.3) for FRDM-KL43z with using Processor Expert for IAR EWARM)
agor53
I have project KDS project for FRDM-KL43z (with using Processor Expert and SDK 1.3, for IAR EWARM).
Now I want to migrate to new SDK 2.0.
I use directions from 'Kinetis SDK 2.0 Transition Guide' (3.8); for migration I download 'KSDK Project Generator', download and install 'New Kinetis SDK 2.x Project Wizard', build and download 'SDK 2.0 for FRDM-KL43z'.
But when I try to use 'KSDK Project Generator' for creating of the new SDK 2 project, I get error about incompatibility of versions of the program and Windows (7, 32bits).
Then I try to use 'New Project wizard' with using 'Kinetis SDK 2.x' and point to folder with unpacked 'SDK 2.0 for FRDM-KL43z', I get error 'Selected directory does not contain Kinetis SDK 2.x for KDS'.
So I can't to migrate.
How to make it correctly?
Thanks advance,
Andrey
MarekTrmac
Hi Andrey,
when you downloading SDK2.0 package, please ensure KDS is selected - see attached picture. Otherwise New Project Wizard in KDS will not work.
Regards, Marek
radoslavapovalo
Hi Andrey,
The new version of KSDK Project Generator which supports Win7-32 bit has been released. You can find it here: Kinetis SDK Project Generator Tool
MarekTrmac
Hi Andrey,
Regards, Marek
agor53
Hi, Marek
Thanks, toolchain was 'IAR', with KDS New Project Wizard creates new project for SDK2 successfully.
But now I need to transfer existing SDK1.3 project to new created SDK2 project.
How to do it the easiest way?
Thanks in advance,
Andrey
MarekTrmac
Andrey, go to http://nxp.com/ksdk - Documentation - User Guides - and you will find there "Kinetis SDK v2.0 Transition Guide".
Marek
