Error on operand write with sinus function
teboulmickael
I try to use sinus function on MCF5213 with Codewarrior. I am using the library C_4i_CF_MSL.a on my projet.
But when my software call the funtion sin this error occurs :
Error generate :
Access Error -- PC = 0X02DEEC
Thanks !
ZhangJennie
please check these points:
1. if math.h is included.
2. adjust ansi_prefix.CF.size.h as :
#define _MSL_FLOATING_POINT 1
//#define _MSL_NO_MATH_LIB 0
#undef _MSL_NO_MATH_LIB
#endif
#define _MSL_FLOATING_POINT_IO 1
3. add
#define __CF_USE_FULL_LIBS__ 1
to prefix text of Target setting -> C/C++Preprocessor
can this help you?
Jennie Zhang
teboulmickael
Thank you very much, you save me :smileyhappy:
Now I have an other problem... M_PI is not recognized.
Do you know how can I use pi (3.14...) ?
