Hi, what is the maximium memory(DDR) size LS1043A support? 2G or 4G? By config linux kernal as LPAE, is it possible LS1043A can access beyond 2GB limitation?
hl123456hua
ufedor
Maximum SDRAM capacity supported by Linux is equal to the LS1043A DDR controller capability - i.e. 64 GB.
scottwood
LS1043A has a 64-bit core, thus you should run a 64-bit kernel, thus you should not need LPAE.
