That's it, that's the question: Is there a way to choose different processor clock rates on the T4240RDB board, either by setting options in the uboot shell, or by recompiling uboot, or ... ?
I tried to search the documentation but I couldn't find the answer.
Thanks for your help!
Solved! Go to Solution.
Of course it is possible using modified RCW.
The RCW is described in the T4240 Reference Manual, 4.6.4.1 RCW Field Definitions:
https://www.nxp.com/webapp/Download?colCode=T4240RM
Current RCW is printed by U-Boot.
It could be imported and modified using the PBL Tool from the QorIQ Configuration and Validation Suite which is bundled with CodeWarrior evaluation version available at:
CodeWarrior Dev Tools for Power Architecture|NXP
The RCW programming is explained in the Linux SDK Documentation:
