Debugger Connection to FRDM-K64F Freedom Module
jerrygardner
I have a FRDM-K64F Freedom Module. How do I connect a Segger J-Link to it? The User's Guide is somewhat unclear on this.
BlackNight
If you are concerned about jumper settings and how to connect:
Debugging the FRDM-K64F with P&E Multilink | MCU on Eclipse
With Segger J-Link it is the same, except that instead a Multilink it is a J-Link.
And of course the settings in the debugger are different, and different for every IDE.
But I hope this helps,
Erich
