Hi all
I have a question about detailed power-up sequence.
In following guide, it shows startup timing diagram in LDO Bypass mode.
But there is no diagram in non LDO Bypass mode.
http://cache.nxp.com/files/32bit/doc/user_guide/IMX6SLHDG.pdf
Please provide me the diagram in non LDO Bypass mode.
Ko-hey
Please follow the Datasheet recommendations, as discussed in the following
thread Re: About Power sequence in i.MX6SL.
Yuri
There are no description about non bypass mode so user have to follow the datasheet recommendation.
Is it correct ?
Ko-hey
