How to check CPU usage in CW10.6?
sourabhpatil
what settings should be done in CW?
trytohelp
Hi Sourabh,
Strange ...
This should be installed by default.
Attached you will find some manuals contained in the \CW MCU v10.6.4\MCU\Help\PDF folder.
Pascal
NXP Technical Support
trytohelp
Hi Sourabh,
CW for MCU V10.6 is supporting several architectures.
Each architecture is using his own build tool chain.
We don't have "generic" answer.
By default all linker can generate a map file which is giving an overview of the memory used by an application.
Depending of the architecture, the linker could provide less or more information.
You will find more details in the manuals at \CW MCU v10.6.4\MCU\Help\PDF folder:
    MCU_Build_Tools_Utilities.pdf for HCs08, RS08 and HCs12Z (search linker or map)
    Targeting_Microcontrollers.pdf for all architectures (search linker or map)
    MCU_"Architecture"_Compiler.pdf you will find some linker, map file info.
Hope this will help
Pascal
sourabhpatil
Hi Pascal,
Thanks for your reply.
I am not able to find above PDF's in \CW MCU v10.6.4\MCU,
Can you please send me the above PDF's?
Sourabh
trytohelp
Hi Sourabh,
Strange ...
Pascal
