frdm-kl43 usb cdc vcom example
alexeyusoltsev
Hi!
I've tryed to launch frdm-kl43 cdc vcom example and failed.
It looks like enumeration went ok COM17 appeared in the device management window:
But i can't get any echoed message from it:
(income messages would be black colored, violets are output messages)
according to readme file i've set:
static bool start_transactions = TRUE;
I must have done something wrong. Help me please.
example imported from KSDK v1.3 and i'am using KDS 3.0.0
Alexey.
Tags (2)
ivadorazinova
Hello Alexey,
please do you have the same results in Tera Term?
Thank you,
Iva
alexeyusoltsev
Hi Iva,
Thanks for fast response!
I dont use Teraterm so can't undertand the result. When I've typed 1234 the cursor came back and did not go to new line.
ivadorazinova
Hello Alexey,
I agree with Konstantin.
Please try to set Termite:
Please let me know, if it works you now.
Thank you.
Iva
alexeyusoltsev
Well!
It worked! Werid that hercules has rts/cts controll too and failed on it.
I thought that
would desable rts/cts control. How can it be desabled?
Thanks for responses! It helped me a lot and now I cant try to modify basic application for my usage.
PitOn
Hi,Alexey.
Set the Flow Control from "none" to "RTS/CTS".
USB Device CDC on KSDK PEx components and KDS 3.0 and KSDK 1.2.0 or KSDK 1.3.0 .
