Webinar: Kinetis K64F and ARM KEIL ULINKpro
MeganHansen
Kinetis fans, take note… If you’re using (or interested in using) ARM Keil ULINK with your Kinetis designs, you may be interested in joining an upcoming webinar hosted by ARM Keil: “Advanced Debug and Trace on NXP TWR-K64F120M using ULINKpro”. In this webinar, you will learn how to use ULINKpro to debug and trace embedded applications on the TWR-K64F120M.
Webinar will include an overview of Kinetis K64F, TWR-K64F120M, and Keil MDK Version 5. Debugging a DSP application running on the K64F using ULINKpro (with trace) will also be shown.
Webinar is free. Register here:  https://attendee.gotowebinar.com/register/5643722089205280257?source=nxp
