IFC NAND not working in Kernel
Question asked by Pranav Madhu on Feb 10, 2016
Latest reply on Feb 15, 2016 by Scott Wood
I'm having a custom LS1021a board. We have a 1GB NAND Flash mounted on IFC  AD0-AD7 line. We are able to access the NAND from u-boot, but it fails on linux. The dmesg for its driver is
[   71.345016] fsl-ifc 153000000010000.ifc: Freescale Integrated Flash Controller
[   71.345037] fsl-ifc 153000000010000.ifc: failed to get memory region
[   97.042203] fsl,ifc-nand 0.ifc: fsl_ifc_nand_probe: failed to get resource
[   97.049056] fsl,ifc-nand: probe of 0.ifc failed with error -22
The device tree modification for ifc is provided below
ls1021a.dtsi
        ifc: ifc@1530000 {
            compatible = "fsl,ifc-nand","simple-bus","fsl,ls1021a-ifc", "fsl,ifc";
            reg = <0x0 0x1530000 0x0 0x10000>;
            interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>;
            status="disabled";
            ranges=<0x0 0x0 0x0 0x7e800000 0x00010000>;
            flash@0,0 {
                            #address-cells = <1>;
                            #size-cells = <1>;
                            compatible = "fsl,ifc-nand";
                            reg = <0x0 0x0 0x10000>;
                            bank-width = <2>;
                            device-width = <1>;
                              partition@0 {
                                   /* 32MB for user data */
                                   reg = <0x0 0x02000000>;
                                   label = "NAND Data";
ls1021a-iot.dts
&ifc {
    status = "okay";
    #size-cells = <1>;
/*    ranges = < 0x1 0x0 0x0 0xffa00000 0x00010000 >;*/
    partition@0 {
        reg = <0x0 0x40000000>;
        label = "NAND Configuration";
and the driver file
fsl_ifc_nand.c
static const struct of_device_id fsl_ifc_nand_match[] = {
        .compatible = "fsl,ifc-nand",
static struct platform_driver fsl_ifc_nand_driver = {
    .driver = {
        .name    = "fsl,ifc-nand",
        .owner = THIS_MODULE,
        .of_match_table = fsl_ifc_nand_match,
    .probe       = fsl_ifc_nand_probe,
    .remove      = fsl_ifc_nand_remove,
Can anyone help me in solving this issue?
Thanks in Advance,
Pranav Madhu
