i.MX6 SabreSD PCI is broken
Question asked by Tarek El-Sherbiny on Feb 5, 2016
Latest reply on Feb 9, 2016 by igorpadykov
Hi All,
I was writing PCI driver on the SabreSD to communicate with Altera FPGA over PCI.
I think I have damaged the PCI port on the chip after unplugging and plugging the FPGA board again. I was very careful to power down both boards before plugging / unplugging but looks like that is not enough.
Now I still can boot the SabreSD board connect UART console and SSH to it but the PCI is not working. I tried a reference PCI Network card and it’s not working.
I tried to investigate the problem and this is my findings:
  • From HW side I can see i.MX6 is sending PCI reference clock going but it is not sending training data on the PCI-Tx.
  • The software does not show any pci device and dmsg shows:
imx6q-pcie 1ffc000.pcie: phy link never came up
imx6q-pcie 1ffc000.pcie: Failed to bring link up!
imx6q-pcie 1ffc000.pcie: failed to initialize host
imx6q-pcie: probe of 1ffc000.pcie failed with error -22
  • Only 2 CPU’s  are running !
# cat /proc/cpu/alignment
User:           0
System:         7
Skipped:        0
Half:           0
Word:           0
DWord:          0
Multi:          7
User faults:    2 (fixup)
root@imx6qsabresd:/sys/devices/system/cpu#
root@imx6qsabresd:/sys/devices/system/cpu# cat /proc/cpuinfo
processor       : 0
model name      : ARMv7 Processor rev 10 (v7l)
BogoMIPS        : 3.00
Features        : swp half thumb fastmult vfp edsp neon vfpv3 tls vfpd32
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x2
CPU part        : 0xc09
CPU revision    : 10
processor       : 1
BogoMIPS        : 3.00
CPU architecture: 7
CPU variant     : 0x2
CPU part        : 0xc09
CPU revision    : 10
Hardware        : Freescale i.MX6 Quad/DualLite (Device Tree)
Revision        : 0000
Serial          : 0000000000000000
Is it possible that I have accidentally disabled the clock “clock gate” some blocks in the Chip? How do I enable it again?
root@imx6qsabresd:/unit_tests# ./dump-clocks.sh
clock                    parent                      flags en_cnt pre_cnt      rate
ckil                        ---                   00000030      0      0      32768
ckih1                       ---                   00000030      0      0          0
osc                         ---                   00000030      6      6   24000000
pll1_bypass_src          osc                      000002a2      1      1   24000000
pll1                     pll1_bypass_src          00000041      1      1  996000000
pll1_bypass              pll1                     000002a6      1      1  996000000
pll1_sys                 pll1_bypass              00000024      1      1  996000000
pll1_sw                  pll1_sys                 000002a0      1      1  996000000
arm                      pll1_sw                  00000004      2      2  996000000
twd                      arm                      00000024      1      1  498000000
pll2_bypass_src          osc                      000002a2      1      1   24000000
pll2                     pll2_bypass_src          00000041      1      1  528000000
pll2_bypass              pll2                     000002a6      1      1  528000000
pll2_bus                 pll2_bypass              00000024      2      2  528000000
pll2_pfd0_352m           pll2_bus                 00000000      0      0  452571428
ldb_di0_sel              pll2_pfd0_352m           000002a4      0      0  452571428
ldb_di0_div_3_5          ldb_di0_sel              00000024      0      0  129306122
ldb_di0_div_7            ldb_di0_sel              00000024      0      0   64653061
ldb_di0_div_sel          ldb_di0_div_7            000002a6      0      0   64653061
ldb_di0                  ldb_di0_div_sel          00000005      0      0   64653061
ldb_di1_sel              pll2_pfd0_352m           000002a4      0      0  452571428
ldb_di1_div_3_5          ldb_di1_sel              00000024      0      0  129306122
ldb_di1_div_7            ldb_di1_sel              00000024      0      0   64653061
ldb_di1_div_sel          ldb_di1_div_7            000002a6      0      0   64653061
ldb_di1                  ldb_di1_div_sel          00000005      0      0   64653061
ipu2_di1_sel             ldb_di1                  000002a6      0      0   64653061
ipu2_di1                 ipu2_di1_sel             00000005      0      0   64653061
ipu2_pclk1_sel           ipu2_di1                 00000000      0      0   64653061
ipu2_pclk1_div           ipu2_pclk1_sel           00000004      0      0   64653061
ipu2_pclk_1              ipu2_pclk1_div           00000004      0      0   64653061
pll2_pfd1_594m           pll2_bus                 00000000      0      0  594000000
gpu3d_shader_sel         pll2_pfd1_594m           000002a2      0      0  594000000
gpu3d_shader             gpu3d_shader_sel         00000025      0      0  594000000
pll2_pfd2_396m           pll2_bus                 00000000      1      1  396000000
pll2_198m                pll2_pfd2_396m           00000024      0      0  198000000
step                     pll2_pfd2_396m           000002a2      0      0  396000000
hsi_tx_sel               pll2_pfd2_396m           000002a2      1      1  396000000
hsi_tx_podf              hsi_tx_sel               00000025      1      1  198000000
hsi_tx                   hsi_tx_podf              00000005      1      1  198000000
usdhc1_sel               pll2_pfd2_396m           00000000      0      0  396000000
usdhc1_podf              usdhc1_sel               00000025      0      0  198000000
usdhc1                   usdhc1_podf              00000005      0      0  198000000
usdhc2_sel               pll2_pfd2_396m           00000000      0      0  396000000
usdhc2_podf              usdhc2_sel               00000025      0      0  198000000
usdhc2                   usdhc2_podf              00000005      0      0  198000000
usdhc3_sel               pll2_pfd2_396m           00000000      0      0  396000000
usdhc3_podf              usdhc3_sel               00000025      0      0  198000000
usdhc3                   usdhc3_podf              00000005      0      0  198000000
gpmi_apb                 usdhc3                   00000005      0      0  198000000
gpmi_bch_apb             usdhc3                   00000005      0      0  198000000
per1_bch                 usdhc3                   00000005      0      0  198000000
apbh_dma                 usdhc3                   00000005      0      0  198000000
usdhc4_sel               pll2_pfd2_396m           00000000      0      0  396000000
usdhc4_podf              usdhc4_sel               00000025      0      0  198000000
usdhc4                   usdhc4_podf              00000005      0      0  198000000
gpmi_bch                 usdhc4                   00000005      0      0  198000000
emi_sel                  pll2_pfd2_396m           00000000      0      0  396000000
emi_podf                 emi_sel                  00000004      0      0  198000000
enfc_sel                 pll2_pfd2_396m           000002a2      0      0  396000000
enfc_pred                enfc_sel                 00000025      0      0   79200000
enfc_podf                enfc_pred                00000025      0      0   19800000
enfc                     enfc_podf                00000005      0      0   19800000
gpmi_io                  enfc                     00000005      0      0   19800000
periph_pre               pll2_bus                 000002a0      1      1  528000000
periph                   periph_pre               00000080      2      2  528000000
ahb                      periph                   00000004      8      8  132000000
ipg                      ahb                      00000025      4      4   66000000
ipg_per                  ipg                      00000004      0      0   66000000
gpt_ipg_per              ipg_per                  00000005      0      0   66000000
i2c1                     ipg_per                  00000005      0      0   66000000
i2c2                     ipg_per                  00000005      0      0   66000000
i2c3                     ipg_per                  00000005      0      0   66000000
pwm1                     ipg_per                  00000005      0      0   66000000
pwm2                     ipg_per                  00000005      0      0   66000000
pwm3                     ipg_per                  00000005      0      0   66000000
pwm4                     ipg_per                  00000005      0      0   66000000
caam_ipg                 ipg                      00000005      1      1   66000000
can1_ipg                 ipg                      00000005      0      0   66000000
can2_ipg                 ipg                      00000005      0      0   66000000
enet                     ipg                      00000005      2      2   66000000
gpt_ipg                  ipg                      00000005      1      1   66000000
iim                      ipg                      00000005      0      0   66000000
spba                     ipg                      00000005      0      0   66000000
spdif_gclk               ipg                      00000005      0      0   66000000
ssi1_ipg                 ipg                      00000005      0      0   66000000
ssi2_ipg                 ipg                      00000005      0      0   66000000
ssi3_ipg                 ipg                      00000005      0      0   66000000
uart_ipg                 ipg                      00000005      1      1   66000000
usboh3                   ipg                      00000005      0      0   66000000
cko1_sel                 ahb                      000002a2      0      0  132000000
cko1_podf                cko1_sel                 00000025      0      0   16500000
cko1                     cko1_podf                00000024      0      0   16500000
asrc_ipg                 ahb                      00000005      0      0  132000000
asrc_mem                 ahb                      00000005      0      0  132000000
caam_mem                 ahb                      00000005      1      1  132000000
caam_aclk                ahb                      00000005      1      1  132000000
esai_ipg                 ahb                      00000005      0      0  132000000
esai_mem                 ahb                      00000005      0      0  132000000
hdmi_iahb                ahb                      00000005      1      1  132000000
ocram                    ahb                      00000004      2      2  132000000
rom                      ahb                      00000005      1      1  132000000
sata                     ahb                      00000005      1      1  132000000
sdma                     ahb                      00000005      8      8  132000000
mmdc_ch0_axi             periph                   00000004      1      1  528000000
ipu1_sel                 mmdc_ch0_axi             000002a2      0      0  528000000
ipu1_podf                ipu1_sel                 00000025      0      0  264000000
dcic1                    ipu1_podf                00000005      0      0  264000000
ipu1                     ipu1_podf                00000005      0      0  264000000
ipu1_pclk0_sel           ipu1                     00000000      0      0  264000000
ipu1_pclk0_div           ipu1_pclk0_sel           00000004      0      0          0
ipu1_pclk_0              ipu1_pclk0_div           00000004      0      0          0
ipu1_pclk1_sel           ipu1                     00000000      0      0  264000000
ipu1_pclk1_div           ipu1_pclk1_sel           00000004      0      0          0
ipu1_pclk_1              ipu1_pclk1_div           00000004      0      0          0
ipu2_sel                 mmdc_ch0_axi             000002a2      0      0  528000000
ipu2_podf                ipu2_sel                 00000025      0      0  264000000
dcic2                    ipu2_podf                00000005      0      0  264000000
ipu2                     ipu2_podf                00000005      0      0  264000000
ipu2_pclk0_sel           ipu2                     00000000      0      0  264000000
ipu2_pclk0_div           ipu2_pclk0_sel           00000004      0      0          0
ipu2_pclk_0              ipu2_pclk0_div           00000004      0      0          0
gpu3d_core_sel           mmdc_ch0_axi             000002a2      0      0  528000000
gpu3d_core_podf          gpu3d_core_sel           00000025      0      0  528000000
gpu3d_core               gpu3d_core_podf          00000005      0      0  528000000
periph2_pre              pll2_bus                 000002a2      0      0  528000000
periph2                  periph2_pre              00000080      0      0  528000000
mmdc_ch1_axi             periph2                  00000004      0      0  528000000
pll3_bypass_src          osc                      000002a2      1      1   24000000
pll3                     pll3_bypass_src          00000041      1      1  480000000
pll3_bypass              pll3                     000002a6      1      1  480000000
pll3_usb_otg             pll3_bypass              00000024      3      3  480000000
usbphy1                  pll3_usb_otg             00000024      0      0  480000000
pll3_pfd0_720m           pll3_usb_otg             00000000      0      0  720000000
pll3_pfd1_540m           pll3_usb_otg             00000000      2      2  540000000
video_27m                pll3_pfd1_540m           00000024      0      0   27000000
hdmi_isfr                pll3_pfd1_540m           00000005      1      1  540000000
axi_alt_sel              pll3_pfd1_540m           000002a2      1      1  540000000
axi_sel                  axi_alt_sel              000002a0      1      1  540000000
axi                      axi_sel                  00000004      2      2  270000000
gpu2d_axi                axi                      000002a2      0      0  270000000
gpu3d_axi                axi                      000002a2      0      0  270000000
pcie_axi_sel             axi                      000002a2      0      0  270000000
pcie_axi                 pcie_axi_sel             00000005      0      0  270000000
emi_slow_sel             axi                      00000000      1      1  270000000
emi_slow_podf            emi_slow_sel             00000004      1      1  135000000
eim_slow                 emi_slow_podf            00000005      2      2  135000000
vdo_axi_sel              axi                      000002a2      0      0  270000000
vdo_axi                  vdo_axi_sel              00000005      0      0  270000000
vdoa                     vdo_axi                  00000005      0      0  270000000
vpu_axi_sel              axi                      000002a2      0      0  270000000
vpu_axi_podf             vpu_axi_sel              00000025      0      0  270000000
vpu_axi                  vpu_axi_podf             00000005      0      0  270000000
mlb                      axi                      00000005      0      0  270000000
openvg_axi               axi                      00000005      0      0  270000000
pll3_pfd2_508m           pll3_usb_otg             00000000      0      0  508235294
ssi1_sel                 pll3_pfd2_508m           00000000      0      0  508235294
ssi1_pred                ssi1_sel                 00000025      0      0  127058823
ssi1_podf                ssi1_pred                00000025      0      0   63529411
ssi1                     ssi1_podf                00000005      0      0   63529411
ssi2_sel                 pll3_pfd2_508m           00000000      0      0  508235294
ssi2_pred                ssi2_sel                 00000025      0      0  127058823
ssi2_podf                ssi2_pred                00000025      0      0   63529411
ssi2                     ssi2_podf                00000005      0      0   63529411
ssi3_sel                 pll3_pfd2_508m           00000000      0      0  508235294
ssi3_pred                ssi3_sel                 00000025      0      0  127058823
ssi3_podf                ssi3_pred                00000025      0      0   63529411
ssi3                     ssi3_podf                00000005      0      0   63529411
pll3_pfd3_454m           pll3_usb_otg             00000000      0      0  454736842
spdif_sel                pll3_pfd3_454m           000002a2      0      0  454736842
spdif_pred               spdif_sel                00000025      0      0  227368421
spdif_podf               spdif_pred               00000025      0      0   28421052
spdif                    spdif_podf               00000005      0      0   28421052
pll3_120m                pll3_usb_otg             00000024      0      0  120000000
pll3_80m                 pll3_usb_otg             00000024      1      1   80000000
uart_serial_podf         pll3_80m                 00000025      1      1   80000000
uart_serial              uart_serial_podf         00000005      1      1   80000000
pll3_60m                 pll3_usb_otg             00000024      0      0   60000000
ecspi_root               pll3_60m                 00000025      0      0   60000000
ecspi1                   ecspi_root               00000005      0      0   60000000
ecspi2                   ecspi_root               00000005      0      0   60000000
ecspi3                   ecspi_root               00000005      0      0   60000000
ecspi4                   ecspi_root               00000005      0      0   60000000
ecspi5                   ecspi_root               00000005      0      0   60000000
can_root                 pll3_60m                 00000025      0      0   30000000
can1_serial              can_root                 00000005      0      0   30000000
can2_serial              can_root                 00000005      0      0   30000000
periph_clk2_sel          pll3_usb_otg             000002a0      0      0  480000000
periph_clk2              periph_clk2_sel          00000025      0      0  480000000
periph2_clk2_sel         pll3_usb_otg             000002a2      0      0  480000000
periph2_clk2             periph2_clk2_sel         00000025      0      0  480000000
esai_sel                 pll3_usb_otg             000002a2      0      0  480000000
esai_pred                esai_sel                 00000025      0      0  240000000
esai_podf                esai_pred                00000025      0      0   30000000
esai_extal               esai_podf                00000005      0      0   30000000
asrc_sel                 pll3_usb_otg             000002a2      0      0  480000000
asrc_pred                asrc_sel                 00000025      0      0  240000000
asrc_podf                asrc_pred                00000025      0      0   30000000
asrc                     asrc_podf                00000005      0      0   30000000
gpu2d_core_sel           pll3_usb_otg             000002a2      0      0  480000000
gpu2d_core_podf          gpu2d_core_sel           00000025      0      0  480000000
gpu2d_core               gpu2d_core_podf          00000005      0      0  480000000
pll4_bypass_src          osc                      000002a2      0      0   24000000
pll4                     pll4_bypass_src          00000041      0      0  147456000
pll4_bypass              pll4                     000002a6      0      0  147456000
pll4_audio               pll4_bypass              00000024      0      0  147456000
pll4_post_div            pll4_audio               00000025      0      0   36864000
pll4_audio_div           pll4_post_div            00000025      0      0   36864000
pll5_bypass_src          osc                      000002a2      0      0   24000000
pll5                     pll5_bypass_src          00000041      0      0  296600000
pll5_bypass              pll5                     000002a6      0      0  296600000
pll5_video               pll5_bypass              00000024      0      0  296600000
pll5_post_div            pll5_video               00000025      0      0   74150000
pll5_video_div           pll5_post_div            00000025      0      0   74150000
ipu1_di0_pre_sel         pll5_video_div           000002a6      0      0   74150000
ipu1_di0_pre             ipu1_di0_pre_sel         00000025      0      0   24716666
ipu1_di0_sel             ipu1_di0_pre             000002a6      0      0   24716666
ipu1_di0                 ipu1_di0_sel             00000005      0      0   24716666
ipu1_di1_pre_sel         pll5_video_div           000002a6      0      0   74150000
ipu1_di1_pre             ipu1_di1_pre_sel         00000025      0      0   24716666
ipu1_di1_sel             ipu1_di1_pre             000002a6      0      0   24716666
ipu1_di1                 ipu1_di1_sel             00000005      0      0   24716666
ipu2_di0_pre_sel         pll5_video_div           000002a6      0      0   74150000
ipu2_di0_pre             ipu2_di0_pre_sel         00000025      0      0   24716666
ipu2_di0_sel             ipu2_di0_pre             000002a6      0      0   24716666
ipu2_di0                 ipu2_di0_sel             00000005      0      0   24716666
ipu2_di1_pre_sel         pll5_video_div           000002a6      0      0   74150000
ipu2_di1_pre             ipu2_di1_pre_sel         00000025      0      0   24716666
pll6_bypass_src          osc                      000002a2      1      1   24000000
pll6                     pll6_bypass_src          00000041      1      1  500000000
pll6_bypass              pll6                     000002a6      1      1  500000000
pll6_enet                pll6_bypass              00000024      1      1  500000000
sata_ref                 pll6_enet                00000024      0      0  100000000
sata_ref_100m            sata_ref                 00000024      0      0  100000000
lvds1_sel                sata_ref                 000002a2      0      0  100000000
lvds1_gate               lvds1_sel                00000004      0      0  100000000
pcie_ref                 pll6_enet                00000024      0      0  125000000
pcie_ref_125m            pcie_ref                 00000024      0      0  125000000
enet_ref                 pll6_enet                00000020      1      1  125000000
pll7_bypass_src          osc                      000002a2      1      1   24000000
pll7                     pll7_bypass_src          00000041      1      1  480000000
pll7_bypass              pll7                     000002a6      1      1  480000000
pll7_usb_host            pll7_bypass              00000024      1      1  480000000
usbphy2                  pll7_usb_host            00000024      1      1  480000000
gpt_3m                   osc                      00000024      1      1    3000000
cko2_sel                 osc                      000002a2      0      0   24000000
cko2_podf                cko2_sel                 00000025      0      0   24000000
cko2                     cko2_podf                00000024      0      0   24000000
cko                      cko2                     000002a2      0      0   24000000
dummy                       ---                   00000030      2      2          0
usbphy1_gate             dummy                    00000024      1      1          0
usbphy2_gate             dummy                    00000024      1      1          0
lvds2_sel                dummy                    000002a2      0      0          0
lvds2_gate               lvds2_sel                00000004      0      0          0
anaclk1                     ---                   00000030      0      0          0
lvds1_in                 anaclk1                  00000004      0      0          0
anaclk2                     ---                   00000030      0      0          0
lvds2_in                 anaclk2                  00000004      0      0          0
orphans                     ---                   00000004      0      0          0
