I'm wanting to know if I could use a 240V power supply for T1024RDB-PC. I understand it came with an 110V connector but sometimes the power supply can handle the extra voltage. Anyone have any experience with this?
Solved! Go to Solution.
The power supply system of the T1024RDB uses power from a standard ATX PSU. So if ATX PSU you get supports 220-240v then you can use it with 220V line. You also can replace the 110V one by a 220V ATX PSU which provides required 12V and 5V powers.
