hi,
I used bitbake core-image-x11 -c populate_sdk and the bit bake is finished without any error. While I am trying to copy the image to sd card I can not found the .sdcard file.Is it different from the normal bit bake command bitbake core-image-base.?Where I can find the .sdcard file?what is the further step I have to proceed? Is bitbake core-image-x11 is not a valid command?Can any body help me to solve this? Please give some link
"After a build is complete, the created image resides in <build directory>/tmp/deploy/images."
Also, please look at Guide to the .sdcard format
Yuri
