Dear all,
We want to operate VPU at 352MHz.
In this case it is necessary to change the VDD_SOC_IN voltage. (1.35V < VDD_SOC_IN)
We have some following questions
(1)
How much does the heat value at VPU=352MHz increase in comparison at VPU=264MHz?
(2)
If VDD_SOC_IN is set to 1.35V or less and VPU is set to 352MHz, what will happen?
May I have advice?
Yuuki
Solved! Go to Solution.
Hi Yuuki
1. I am afraid such data is not available, just as rough estimation one
can expect increase by factor 1.7=(352/264)**2, assuming current is
proportinal frequency.
2. vpu will not work as expected, for example produce bad image quality
Hi Yuuki
