HDMI Dispaly
HDMI Dispaly
prasads
I am using imx6 sabre auto development board.i used a HDMI converter cable by connecting  to VGA monitor for the display.But i am not able to get any display in my VGA monitor.
I used the environment variables for HDM to set in commanline arguments:
setenv bootargs 'console=ttymxc3,115200 init=/init video=mxcfb0:dev=hdmi,1920x1080M@60bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=400M androidboot.console=ttymxc3 consoleblank=0 androidboot.hardware=freescale cma=384M androidboot.serialno=112029d4df666d04'
Please find the hdmi logs below:
booti mmc1
kernel   @ 14008000 (6821344)
ramdisk  @ 15000000 (726561)
fdt      @ 14f00000 (50597)
kernel cmdline:
        use boot.img command line:
        console=ttymxc3,115200 androidboot.console=ttymxc3 init=/init video=mxcfb0:dev=hdmi,640x480M@60,bpp=32 video=mxcfb1:off video=mxcfb2:o4
   Using Device Tree in place at 14f00000, end 14f0f5a4
Starting kernel ...
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpu
Initializing cgroup subsys cpuacct
Linux version 3.10.53 (khirod@root-T430) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #48 SMP PREEMPT Wed Feb 3 03:00:03 IST 2016
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX6 Quad/DualLite (Device Tree), model: Freescale i.MX6 Quad SABRE Automotive Board
cma: CMA: reserved 384 MiB at 66000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 8 pages/cpu @82008000 s9728 r8192 d14848 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520464
Kernel command line: console=ttymxc3,115200 androidboot.console=ttymxc3 init=/init video=mxcfb0:dev=hdmi,640x480M@60,bpp=32 video=mxcfb1:off v4
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
Memory: 1983MB 64MB = 2047MB total
Memory: 1666872k/1666872k available, 430280k reserved, 269312K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    lowmem  : 0x80000000 - 0xef800000   (1784 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x80e7b484   (14798 kB)
      .init : 0x80e7c000 - 0x80ed0600   ( 338 kB)
      .data : 0x80ed2000 - 0x80f56000   ( 528 kB)
       .bss : 0x80f56000 - 0x80feacf8   ( 596 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
NR_IRQS:16 nr_irqs:16 16
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
CPU identified as i.MX6Q, silicon rev 1.2
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
Security Framework initialized
SELinux:  Initializing.
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys freezer
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x807e31d0 - 0x807e3228
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU2: Booted secondary processor
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU3: Booted secondary processor
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
DMA: preallocated 256 KiB pool for atomic coherent allocations
Use WDOG1 as reset source
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1100 mV
vdd3p0: 2625 <--> 3400 mV at 3000 mV
vdd2p5: 2000 <--> 2750 mV at 2400 mV
cpu: 725 <--> 1450 mV at 1150 mV
vddpu: 725 <--> 1450 mV
vddsoc: 725 <--> 1450 mV at 1175 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
mxs-dma 110000.dma-apbh: initialized
cs42888_supply: 3300 mV
vio1: 3300 mV
vio2: 3300 mV
vd: 3300 mV
va: 5000 mV
platform usb_h1_vbus.33: Driver reg-fixed-voltage requests probe deferral
platform usb_otg_vbus.34: Driver reg-fixed-voltage requests probe deferral
3P3V: 3300 mV
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
pureg-dummy: no parameters
Switching to clocksource mxc_timer1
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP: reno registered
UDP hash table entries: 1024 (order: 3, 32768 bytes)
UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 708K (85000000 - 850b1000)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
mxc_epit: probe of 20d0000.epit failed with error -22
mxc_epit: probe of 20d4000.epit failed with error -22
imx6_busfreq busfreq.16: DDR medium rate not supported.
Bus freq driver module loaded
console [pstore-1] enabled
ramoops: attached 0x100000@0x8bf00000, ecc: 0/0
mxc_ramoops device success loaded
futex hash table entries: 1024 (order: 4, 65536 bytes)
audit: initializing netlink socket (disabled)
type=2000 audit(0.490:1): initialized
bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
NTFS driver 2.1.30 [Flags: R/W DEBUG].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 3498
io scheduler noop registered
MIPI DSI driver module loaded
mxc_hdmi 20e0000.hdmi_video: hdcp disable
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_disp_init
mxc_hdmi_disp_init: JAi Khirod
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_disp_init - default mode 640x480M@60 bpp=32
mxc_hdmi 20e0000.hdmi_video: Enabled HDMI clocks
mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
fbcvt: 640x480@60: CVT Name - .307M3
Ranjini printing &m in disp_init
fb_videomode = 59 640 480 42105 80 16 3 13 64 4 2 0 32
Ranjini printing cmode table...
fb_videomode = 120 1280 720 6734 220 110 20 5 40 5 3 32 0
Ranjini printing mode we are searching...
Ranjini diff -1
Ranjini d ... 880
Ranjini Best found if condition........... = 0
fb_videomode = 100 1280 720 6734 220 440 20 5 40 5 3 32 0
Ranjini diff 880
Ranjini d ... 880Ranjini Best found else condition........... = 0
fb_videomode = 30 1920 1080 13468 148 88 36 4 44 5 3 32 0
Ranjini diff 880
Ranjini d ... 1880Ranjini printing cmode table...
fb_videomode = 25 1920 1080 13468 148 528 36 4 44 5 3 32 0
Ranjini diff 880
fb_videomode = 24 1920 1080 13468 148 638 36 4 44 5 3 32 0
Ranjini diff 880
fb_videomode = 50 1920 1080 6734 148 528 36 4 44 5 3 32 0
Ranjini diff 880
fb_videomode = 50 1440 576 18518 136 24 39 5 128 5 0 32 0
Ranjini diff 880
Ranjini d ... 896Ranjini printing cmode table...
fb_videomode = 50 1440 576 18518 136 24 39 5 128 5 0 16 0
Ranjini diff 880
fb_videomode = 50 1440 288 37037 138 24 19 2 126 3 0 32 0
Ranjini diff 880
Ranjini d ... 992Ranjini printing cmode table...
fb_videomode = 50 1440 288 37037 138 24 19 2 126 3 0 16 0
Ranjini diff 880
fb_videomode = 50 1280 720 13468 220 440 20 5 40 5 3 32 0
Ranjini diff 880
fb_videomode = 50 720 576 37037 68 12 39 5 64 5 0 32 0
Ranjini diff 880
Ranjini d ... 176
fb_videomode = 50 720 576 37037 68 12 39 5 64 5 0 16 0
Ranjini diff 176
Ranjini d ... 176Ranjini Best found else condition........... = 0
fb_videomode = 60 1920 1080 6734 148 88 36 4 44 5 3 32 0
Ranjini diff 176
fb_videomode = 60 1440 480 18500 120 32 30 9 124 6 0 32 0
Ranjini diff 176
Ranjini d ... 800Ranjini printing cmode table...
fb_videomode = 60 1440 480 18500 120 32 30 9 124 6 0 16 0
Ranjini diff 176
fb_videomode = 60 1440 240 37108 114 38 15 4 124 3 0 32 0
Ranjini diff 176
Ranjini d ... 1040Ranjini printing cmode table...
fb_videomode = 60 1440 240 37108 114 38 15 4 124 3 0 16 0
Ranjini diff 176
fb_videomode = 60 1280 720 13468 220 110 20 5 40 5 3 32 0
Ranjini diff 176
Ranjini d ... 880Ranjini printing cmode table...
fb_videomode = 60 720 480 37037 60 16 30 9 62 6 0 32 0
Ranjini diff 176
Ranjini d ... 80
fb_videomode = 60 720 480 37037 60 16 30 9 62 6 0 16 0
Ranjini diff 80
Ranjini d ... 80Ranjini Best found else condition........... = 0
fb_videomode = 59 640 480 39722 48 16 33 10 96 2 0 16 0
Ranjini diff 80
Ranjini d ... 0
Ranjini Finally Returning best .......... = 0
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_disp_init exit
mxc_hdmi 20e0000.hdmi_video: Ranjini mxc_hdmi_disp_init exit ret before err 0
mxc_dispdrv_gethandle,driver initialization entry=0
hdmi Ranjini..........mxc_dispdrv_gethandle List  name hdmi Ranjini..........mxc_dispdrv_gethandle name
mxcfb_dispdrv_init, khiroddisplay driver handle: ret=-734542400mxc_sdc_fb fb.23: registered mxc display driver hdmi
fb_match_mode, khirodmode equal value: m=-734537080
fb_match_mode, khirodmode equal value: m=-734537144
fb_match_mode, khirodmode equal value: m=-734537208
fb_match_mode, khirodmode equal value: m=-734537272
fb_match_mode, khirodmode equal value: m=-734537336
fb_match_mode, khirodmode equal value: m=-734537400
fb_match_mode, khirodmode equal value: m=-734537464
fb_match_mode, khirodmode equal value: m=-734537528
fb_match_mode, khirodmode equal value: m=-734537592
fb_match_mode, khirodmode equal value: m=-734537656
fb_match_mode, khirodmode equal value: m=-734537720
fb_match_mode, khirodmode equal value: m=-734537784
fb_match_mode, khirodmode equal value: m=-734537848
fb_match_mode, khirodmode equal value: m=-734537912
fb_match_mode, khirodmode equal value: m=-734537976
fb_match_mode, khirodmode equal value: m=-734538040
fb_match_mode, khirodmode equal value: m=-734538104
fb_match_mode, khirodmode equal value: m=-734538168
fb_match_mode, khirodmode equal value: m=-734538232
fb_match_mode, khirodmode equal value: m=-734538296
fb_match_mode, khirodmode equal value: m=-734538360
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_phy_init
mxc_hdmi 20e0000.hdmi_video: event=FB_EVENT_MODE_CHANGE
Ranjini FB_EVENT_MODE_CHANGE .. mode
fb_videomode = 59 640 480 39722 48 16 33 10 96 2 0 16 32
Ranjini FB_EVENT_MODE_CHANGE .. &hdmi->previous_non_vga_mode
fb_videomode = 0 0 0 0 0 0 0 0 0 0 0 0 0
Ranjini hdmi->fb_reg 0
mxc_hdmi 20e0000.hdmi_video: event=FB_EVENT_BLANK - UNBLANK
Console: switching to colour frame buffer device 80x30
mxc_hdmi 20e0000.hdmi_video: event=FB_EVENT_FB_REGISTERED
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_fb_registered
mxc_sdc_fb fb.24: Can't get fb option for mxcfb1!
mxc_sdc_fb fb.25: Can't get fb option for mxcfb2!
ldb Ranjini..........mxc_dispdrv_gethandle List  name ldb Ranjini..........mxc_dispdrv_gethandle name
mxcfb_dispdrv_init, khiroddisplay driver handle: ret=-734545984mxc_sdc_fb fb.26: registered mxc display driver ldb
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_cable_connected
Ranjini Entering mxc_hdmi_read_edid....
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_read_edid
unable to read EDID block
mxc_hdmi 20e0000.hdmi_video: read failed
Ranjini Entering mxc_hdmi_read_edid Failing HDMI_EDID_FAIL....
Ranjini .... mxc_hdmi_read_edid edid status ...is -1mxc_hdmi 20e0000.hdmi_video: Read EDID again
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: initialized
imx-sdma 20ec000.sdma: loaded firmware 1.1
pfuze100-regulator 0-0008: Full lay: 1, Metal lay: 1
pfuze100-regulator 0-0008: FAB: 0, FIN: 0
pfuze100-regulator 0-0008: pfuze100 found.
SW1AB: 300 <--> 1875 mV
pfuze100-regulator 0-0008: ramp failed, err -5
SW1C: failed to set ramp_delay
pfuze100-regulator 0-0008: register regulatorSW1C failed
pfuze100-regulator: probe of 0-0008 failed with error -5
Serial: IMX driver
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
Ranjini ... Coming to default..
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_default_modelist
mxc_hdmi 20e0000.hdmi_video: create default modelist
Ranjini diff -1
Ranjini d ... 880
Ranjini diff 880
Ranjini d ... 880
Ranjini diff 880
Ranjini d ... 1880
Ranjini diff 880
Ranjini d ... 1880
Ranjini diff 880
Ranjini d ... 1880
Ranjini diff 880
Ranjini d ... 1880
Ranjini diff 880
Ranjini d ... 896
Ranjini diff 880
Ranjini d ... 896
Ranjini diff 880
Ranjini d ... 992
Ranjini diff 880
Ranjini d ... 992
Ranjini diff 880
Ranjini d ... 880
Ranjini diff 880
Ranjini d ... 176
Ranjini diff 176
Ranjini d ... 176
Ranjini diff 176
Ranjini d ... 1880
Ranjini diff 176
Ranjini d ... 800
Ranjini diff 176
Ranjini d ... 800
Ranjini diff 176
Ranjini d ... 1040
Ranjini diff 176
Ranjini d ... 1040
Ranjini diff 176
Ranjini d ... 880
Ranjini diff 176
Ranjini d ... 80
Ranjini diff 80
Ranjini d ... 80
Ranjini diff 80
Ranjini d ... 0
fb_match_mode, khirodmode equal value: m=-733705272
fb_match_mode, khirodmode equal value: m=-733705336
fb_match_mode, khirodmode equal value: m=-733705400
fb_match_mode, khirodmode equal value: m=-733705464
fb_match_mode, khirodmode equal value: m=-733705528
fb_match_mode, khirodmode equal value: m=-733705592
fb_match_mode, khirodmode equal value: m=-733705656
fb_match_mode, khirodmode equal value: m=-733705720
fb_match_mode, khirodmode equal value: m=-733705784
fb_match_mode, khirodmode equal value: m=-733705848
fb_match_mode, khirodmode equal value: m=-733705912
fb_match_mode, khirodmode equal value: m=-733705976
fb_match_mode, khirodmode equal value: m=-733706040
fb_match_mode, khirodmode equal value: m=-733706104
fb_match_mode, khirodmode equal value: m=-733706168
fb_match_mode, khirodmode equal value: m=-733706232
fb_match_mode, khirodmode equal value: m=-733706296
fb_match_mode, khirodmode equal value: m=-733706360
fb_match_mode, khirodmode equal value: m=-733706424
fb_match_mode, khirodmode equal value: m=-733706488
console [ttymxc3] enabled
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
si476x-core 0-0063: Using default platform data.
si476x-core 0-0063: No IRQ number specified, will use polling
si476x-core 0-0063: Error while sending command 0x11
si476x-core 0-0063: The device in inconsistent power state
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
CAN device driver interface
flexcan 2094000.can: device registered (reg_base=f01e8000, irq=143)
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
fb_match_mode, khirodmode equal value: m=-733706552
mxc_hdmi 20e0000.hdmi_video: hdmi_phy_configure
platform 2184000.usb: Driver imx_usb requests probe deferral
imx_usb 2184200.usb: Can't register ci_hdrc platform device, err=-517
platform 2184200.usb: Driver imx_usb requests probe deferral
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
usbcore: registered new interface driver wacom
egalax_ts 0-0004: Failed to wake up, disable suspend,otherwise it can not wake up
egalax_ts 0-0004: Failed to read firmware version
egalax_ts: probe of 0-0004 failed with error -5
input: isl29023 light sensor as /devices/virtual/input/input0
isl29023 1-0044: driver version 1.0 enabled
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
i2c /dev entries driver
DBG sensor data is at 80fc48a0
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_set_mode
Ranjini diff -1
Ranjini d ... 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini d ... 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini d ... 80
Ranjini diff 80
Ranjini diff 80
Ranjini d ... 0
Ranjini fb_find_nearest_mode
Ranjini Printing non_vga_mode
Ranjini Printing mode
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_setup
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_setup - video mode changed
Ranjini diff -1
Ranjini d ... 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini d ... 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini d ... 80
Ranjini diff 80
Ranjini diff 80
Ranjini d ... 0
mxc_hdmi 20e0000.hdmi_video: CEA mode used vic=1
mxc_hdmi 20e0000.hdmi_video: hdmi_av_composer
mxc_hdmi 20e0000.hdmi_video: final pixclk = 24780000
mxc_hdmi 20e0000.hdmi_video: hdmi_av_composer exit
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_enable_video_path
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_setup CEA mode
mxc_hdmi 20e0000.hdmi_video: hdmi_enable_audio_clk
mxc_hdmi 20e0000.hdmi_video: set up AVI frame
Ranjini diff -1
Ranjini d ... 880
mxc_v4l2_output v4l2_out.41: V4L2 device registered as video16
mxc_v4l2_output v4l2_out.41: V4L2 device registered as video17
mxc_v4l2_output v4l2_out.41: V4L2 device registered as video18
mxc_v4l2_output v4l2_out.41: V4L2 device registered as video19
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
gspca_main: v2.14.0 registered
mag3110 1-000e: check mag3110 chip ID
input: FreescaleMagnetometer as /devices/virtual/input/input1
input: eCompass as /devices/virtual/input/input2
Ranjini diff 880
Ranjini diff 880
Ranjini d ... 1880Ranjini printing cmode table...mag3110 1-000e: mag3110 is probed
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini diff 880
Ranjini d ... 992Ranjini printing cmode table...input: FreescaleAccelerometer as /devices/virtual/input/input3
mma8x5x device driver probe successfully
imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver btusb
cpuidle: using governor ladder
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
mmc2: no vqmmc regulator found
mmc2: no vmmc regulator found
Ranjini diff 880
Ranjini printing cmode table...mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
Galcore version 5.0.11.25762
Ranjini diff 880
Ranjini d ... 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
mmc2: Problem setting current limit!
Ranjini diff 176
Ranjini diff 176
Ranjini diff 176
Ranjini d ... 80
Ranjini diff 80
Ranjini diff 80
Ranjini d ... 0
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_setup exit
mmc2: new ultra high speed DDR50 SDHC card at address aaaa
mmcblk2: mmc2:aaaa SL16G 14.8 GiB
mxc_hdmi 20e0000.hdmi_video: mxc_hdmi_cable_connected exit
mmcblk2: p1 p2 p3 < p5 p6 p7 p8 p9 > p4
mmcblk2: p4 size 28936192 extends beyond EOD, truncated
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_asrc 2034000.asrc: mxc_asrc registered
mxc_vpu 2040000.vpu: VPU initialized
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ashmem: initialized
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
usbcore: registered new interface driver snd-usb-audio
cs42xx8 0-0048: found device, revision 4
snd-soc-dummy snd-soc-dummy: ASoC: Failed to create platform debugfs directory
imx-cs42888 sound-cs42888.36:  cs42888 <-> 2024000.esai mapping ok
imx-cs42888 sound-cs42888.36:  snd-soc-dummy-dai <-> asrc_p2p.3 mapping ok
imx-spdif sound-spdif.39:  dir-hifi <-> 2004000.spdif mapping ok
imx-audio-hdmi sound-hdmi.38:  hdmi-hifi <-> hdmi_audio.17 mapping ok
imx-tuner-si476x sound-fm.37: failed to find FM platform device
imx-tuner-si476x: probe of sound-fm.37 failed with error -22
NET: Registered protocol family 26
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
ctnetlink v0.93: registering with nfnetlink.
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
regulator-dummy: disabling
imx mcc test is registered.
usb_h1_vbus: 5000 mV
usb_otg_vbus: 5000 mV
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 3.10.53 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
file system registered
android_usb gadget: Mass Storage Function, version: 2009/09/11
android_usb gadget: Number of LUNs=1
lun0: LUN: removable file: (no medium)
android_usb gadget: android_usb ready
input: gpio-keys.20 as /devices/soc0/gpio-keys.20/input/input4
snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:49:08 UTC (2948)
ALSA device list:
  #0: cs42888-audio
  #1: imx-spdif
  #2: imx-hdmi-soc
Freeing unused kernel memory: 336K (80e7c000 - 80ed0000)
type=1403 audit(2948.760:2): policy loaded auid=4294967295 ses=4294967295
type=1404 audit(2948.770:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
init: /init.rc: 456: invalid command 'mknod'
init: /dev/hw_random not found
Console: switching to colour dummy device 80x30
EXT4-fs (mmcblk2p5): barriers disabled
EXT4-fs (mmcblk2p5): recovery complete
EXT4-fs (mmcblk2p5): mounted filesystem with ordered data mode. Opts: barrier=0
fs_mgr: __mount(source=/dev/block/mmcblk2p5,target=/system,type=ext4)=0
EXT4-fs (mmcblk2p4): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p4): recovery complete
EXT4-fs (mmcblk2p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
fs_mgr: __mount(source=/dev/block/mmcblk2p4,target=/data,type=ext4)=0
EXT4-fs (mmcblk2p6): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p6): recovery complete
EXT4-fs (mmcblk2p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
fs_mgr: __mount(source=/dev/block/mmcblk2p6,target=/cache,type=ext4)=0
EXT4-fs (mmcblk2p7): mounted filesystem with ordered data mode. Opts: (null)
fs_mgr: __mount(source=/dev/block/mmcblk2p7,target=/device,type=ext4)=0
binder: 144:144 transaction failed 29189, size 0-0
init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
android_usb: already disabled
read descriptors
read strings
mtp_bind_config
root@sabreauto_6q:/ # android_work: sent uevent USB_STATE=CONNECTED
ci_hdrc ci_hdrc.0: freeing queued request
android_work: sent uevent USB_STATE=DISCONNECTED
android_usb gadget: high-speed config #1: android
android_work: sent uevent USB_STATE=CONFIGURED
healthd: No battery devices found
Ranjini hdmi->fb_reg 1
imx-ipuv3 2800000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
warning: `main' uses 32-bit capabilities (legacy support in use)
period 102593883 ,timeout is 102602473, wake up is :0
request_suspend_state: wakeup (3->0) at 19292101001 (1970-01-01 00:49:21.573591334 UTC)
lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
lowmemorykiller: oom_adj 0 => oom_score_adj 0
lowmemorykiller: oom_adj 1 => oom_score_adj 58
lowmemorykiller: oom_adj 2 => oom_score_adj 117
lowmemorykiller: oom_adj 3 => oom_score_adj 176
lowmemorykiller: oom_adj 9 => oom_score_adj 529
lowmemorykiller: oom_adj 15 => oom_score_adj 1000
acc_open
acc_release
fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:01, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
mtp_open
binder: undelivered transaction 3728
ERROR: unrecognized std! ffffff (PAL=ff, NTSC=b000
period 66 ,timeout is 0, wake up is :0
mma enable setting active
mma enable setting inactive
request_suspend_state: sleep (0->3) at 48159590671 (1970-01-01 00:49:50.441081004 UTC)
active wake lock gadget
Prasad
jamesbone
Hello Prasad,
This cable converters from HDMI to VGA does not work if both of your devices that you are trying to attach had both interfaces, since the VGA it is an Analog signal and the HDMI it is a Digital one.  A cable it is not enough to make the change you need a black box to make this happens
prasads
Hi, i also try by
connecting hdmi cabke to tv from board.i was geting in log like edid data
read failed.
Regards, Prasad
jamesbone
which one has the HDMI the TV or the i.MX?.  The TV most have both  Inputs HDMI and VGA and this way it works.
prasads
Hi james,
i connect the HDMI cable to tv in HDMI mode.previously I also getting
display by connecting this converter cable from wandboard to VGA
monitor.but in Sabre auto quad board,i did not get any display.
Prasad
On Mon, Feb 8, 2016 at 11:36 PM, jamesbone <admin@community.freescale.com>
