We are using i.Mx53 processor , following are the questions which we have some clarification.
--> Where can we get the LTIB Source code or Software Source code for i.Mx53.If it is possible can you post me the link below.
--> In iMx53 is there support for H.264 and MPEG4 both in hardware and software ?
--> Are there any Binaries/Firmware required to be loaded for VPU and IPU drivers in i.Mx53 processor for the VPU and IPU to work ?
Thank you,
Deepanraj.A
Solved! Go to Solution.
Please use the following links to get (supported) sources and documentation.
Summary Page :
Please use documentation to get more details.
Yuri
Are there any Binaries/Firmware required to be loaded for VPU and IPU , in i.Mx53 processor for the VPU and IPU to work ?
Thank you,
Deepanraj
Summary Page :
Yuri
