If I wished to use memory write operations to fill a FIFO rather than use DMA will the PCIe controller in the P1011 generate a single TLP transaction with a sixteen byte data field if the write transaction was targeted to a data type defined to be of type 4 x 32 bit.
Thanks Anthony
The request is not clear.
Which exactly operation is in question?
What exactly do you mean?
