Flash programmer and Hardware Diagnostics connection fail
Question asked by Evan Lim on Feb 3, 2016
Latest reply on Feb 12, 2016 by Pascal Irrle
I'm using MobileGT Processor with CodeWarrior TAP. After connecting to my target board (power on), "TX/RX" LED is in flashing green and "Run/pause" LED is in red.
I continue to carry out my test using Flash Programmer and Hardware Diagnostics but it shows "Error. Connect Failed"
I had already install and replace with new css folder. My target board is power up correctly.
May I know what are the other possible problem that caused that error?
Thank You.
Evan
