9S12XEP100: how to access variable in RPAGE?
Question asked by TIM NGUYEN on Feb 3, 2016
Latest reply on Feb 4, 2016 by Edward Karpicz
I need to assign many variables in the multiple RPAGEs (due to total number of vars exceed the one RPAGE size)
To access a var in RPAGE, the Freescale technical document TN238 shows as follows:
#pragma DATA_SEG __RPAGE_SEG PAGED_RAM
unsigned char rub_far_var;
#pragma DATA_SEG DEFAULT
A pointer pointing to such a variable can be defined as follows:
unsigned char * __rptr ptr_on_far_var;
Then assign the pointer to this var
ptr_on_far_var = &rub_far_var;
if you want to access this var, you need to use this pointer.
ptr_on_far_var = 5;
if (ptr_on_far_var == 5)
My question is that can I just assign __far var instead?
all I need to do is as follows:
#pragma DATA_SEG PAGED_RAM
unsigned char __far rub_far_var;
rub_far_var = 5;
the compiler should know where to allocate the var in the RPAGE, retrieve the var from the correct RPAGE
and function the same as __rptr. So I don't need to assign an extra pointer for every variable in the code.
It seems to work. I would like a confirmation.
