I am at the edge of selecting our ZigBee and Thread Device and am torn between MKW21D512, MKW22D512 and MKW24D512. Are these devices pin compatible. What I think is MKW21D512 is not compatible with 22D and 24D. Can someone confirm this? Also all devices share the same memory properties so I assume they all support ZigBee and Thread simultaneously (I know only 24D supports SE 2.0 profile, I dont know the reason though, can someone also point out why?)
Thanks in advance for help,
Mete
Solved! Go to Solution.
Hello Mete,
As you can see MKW2xD Reference Manual, these three devices have differences only in the Smart Energy, USB and FlexMemory support.
Earl Ramírez.
Hello Mete,
Earl Ramírez.
