I have build the "fsl-image-full" using SDK1.8 yocto build environment for P2041RDB. after Image build is done in images folder I have below files...
please let me know how to boot linux on p2041rdb using above files....
as far as i know we need 3 files (kernel, ramdisk and dtb file) to boot linux... but here i could see 2 dtb files, modules-p2041rdb.tgz and fman_ucode.bin files...
how to use them...
Veerendranath
Some of the files in your image directory are symlinks that point
to another files in the same directory. If you are not familiar with
Linux soft links, study this:
You need the files pointed by uImage (kernel binary),
fsl-image-full-p2041rdb.tar.gz (root filesystem image)
one of fsl_fman_ucode* (refer to the link below on how to select)
and one of uImage-p2041rdb, uImage-p2041rdb-usdpaa,
uImage-p2041rdb-usdpaa-shared-interfaces.dtb, depending on whether
or not you are going to work with USDPAA.
For deployment instructions for your board refer to the document at the
link below:
Platon
