problem with segger J-link
Question asked by Massimiliano Cialdi on Feb 1, 2016
Latest reply on Feb 1, 2016 by ZhangJennie
I have an error in KDS 3.0.0 when I select J-link in debug configuration:
!ENTRY org.eclipse.jface 4 2 2016-02-01 11:15:57.204 !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface". !STACK 0 java.lang.NoClassDefFoundError: ilg/gnuarmeclipse/debug/gdbjtag/data/CProjectAttributes     at ilg.gnuarmeclipse.debug.gdbjtag.jlink.ui.TabDebugger.initializeFrom(TabDebugger.java:1199)     at org.eclipse.debug.ui.AbstractLaunchConfigurationTabGroup.initializeFrom(AbstractLaunchConfigurationTabGroup.java:90)     at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationTabGroupWrapper.initializeFrom(LaunchConfigurationTabGroupWrapper.java:201)     at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationTabGroupViewer.displayInstanceTabs(LaunchConfigurationTabGroupViewer.java:764)     at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationTabGroupViewer$8.run(LaunchConfigurationTabGroupViewer.java:635)     at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)     at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationTabGroupViewer.inputChanged(LaunchConfigurationTabGroupViewer.java:652)     at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationTabGroupViewer.setInput0(LaunchConfigurationTabGroupViewer.java:613)     at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationTabGroupViewer.setInput(LaunchConfigurationTabGroupViewer.java:588)     at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog.handleLaunchConfigurationSelectionChanged(LaunchConfigurationsDialog.java:960)     at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog$3.selectionChanged(LaunchConfigurationsDialog.java:573)     at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:876)     at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)     at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)     at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:178)     at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java:873)     at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(StructuredViewer.java:1217)     at org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected(StructuredViewer.java:1243)     at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(OpenStrategy.java:265)     at org.eclipse.jface.util.OpenStrategy.access$5(OpenStrategy.java:259)     at org.eclipse.jface.util.OpenStrategy$1$2.run(OpenStrategy.java:440)     at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)     at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:136)     at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3774)     at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3412)     at org.eclipse.jface.window.Window.runEventLoop(Window.java:832)     at org.eclipse.jface.window.Window.open(Window.java:808)     at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog.open(LaunchConfigurationsDialog.java:1154)     at org.eclipse.debug.ui.DebugUITools$2.run(DebugUITools.java:611)     at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)     at org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDialogOnGroup(DebugUITools.java:619)     at org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDialogOnGroup(DebugUITools.java:552)     at org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(OpenLaunchDialogAction.java:82)     at org.eclipse.jface.action.Action.runWithEvent(Action.java:519)     at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595)     at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511)     at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:420)     at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)     at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4454)     at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1388)     at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3799)     at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3409)     at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)     at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)     at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)     at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)     at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)     at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)     at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)     at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)     at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)     at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)     at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)     at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)     at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)     at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)     at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)     at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)     at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)     at java.lang.reflect.Method.invoke(Unknown Source)     at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)     at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)     at org.eclipse.equinox.launcher.Main.run(Main.java:1465)     at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
The debug Button is never enabled, and I think that this is because of the exception.
Do I need to install some other KDS component or plugin?
best regards
Max
