About a Wi-Fi module supported in AndroidL5.0 for i.MX6
yuuki
Senior Contributor II
Dear all,
AndroidKK4.4.x of i.MX6 supported a module of Atheros and Silex.
However, these are not listed in release note of AndoridL5.x.
Does AndoridL5.0 support a module of Atheros and Silex?
Yuuki
Labels (2)
Hi Yuuki
L5.0.0 supports Silex, L5.1.1 not, refer to attached Release Notes
Hi Yuuki
yuuki
Dear Igor-san,
Thank you for your support.
Noted with thanks.
By the way, do you understand the reason not to support it in L5 .1.1?
Yuuki
Hi Yuuki
seems drivers are not available for L5.1.1,
since it uses more new kernel.
yuuki
Dear Igor-san,
Thank you.
I understand.
Yuuki
