Unable to play videos through qtmultimedia using gstreamer-1.0 for imx6 by yocto build image. Showing No m_videoSink available!
Question asked by Madhu Reddy on Jan 28, 2016
Hello All,
I am unable to play videos through qtmultimedia gstreamer-1.0 for imx6.
meta-qt5: dizzy
from HMI, i am trying to play video, it showing the below message.
root@nitrogen6x:~# ./HMI_IVI_APP_2.2/HMI_IVI_APP/HMI_IVI_APP --platform eglfs &
[1] 318
root@nitrogen6x:~# QEglFSImx6Hooks will set environment variable FB_MULTI_BUFFER=2 to enable double buffering and vsync.
If this is not desired, you can override this via: export QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1
Unable to query physical screen size, defaulting to 100 dpi.
To override, set QT_QPA_EGLFS_PHYSICAL_WIDTH and QT_QPA_EGLFS_PHYSICAL_HEIGHT (in millimeters).
libpng warning: iCCP: known incorrect sRGB profile
qml: disabling the mouse area
qml: @ normal screen
qml: From JS file To 1
qml: Current index = 1
qml: enabling the mouse area
qml: 3
qml: [file:///home/root/HMI_IVI_APP_2.2/HMI_IVI_APP/C++ Qt 40 - QMap.mp4]
qml: @ Before loading Global.filename file:///home/root/HMI_IVI_APP_2.2/HMI_IVI_APP/C++ Qt 40 - QMap.mp4
Could not resolve property : Polkadots-largewhite
qml: @ full screen
====== AIUR: 4.0.3 build on Jan 20 2016 23:33:57. ======
Core: MPEG4PARSER_06.09.00 build on Apr 16 2014 02:20:23
file: /usr/lib/imx-mm/parser/lib_mp4_parser_arm11_elinux.so.3.2
[1]+ Done(1) ./HMI_IVI_APP_2.2/HMI_IVI_APP/HMI_IVI_APP --platform eglfs
Original Attachment has been moved to: m_videoSink_not_available_log.txt.zip
