Hi I want to connect several mass storage devices to a kinetis L microcontroller through an USB hub. Is this possible?
Micrcontroller USB Host---->USB HUB---->Several USB Mass Storage Devices
Tom
Solved! Go to Solution.
Hi Thomas Ost,
Yes, you can connect Several USB MSD device to the USB HUB, then connect to the KL USB host.
Wish it helps you!
If you still have question, please contact with me!
Jingjing
Hi Thomas Ost,
Wish it helps you!
Jingjing
