Base address for analog part of USB PHY on i.MX28
FredrikMoller
I can't find the base address for USB_ANALOG in the reference manual. I figured it could be one of the base addresses for the two USBPHY blocks (0x8007C000 and 0x8007E000), but that doesn't seems to be the case. Where is the base address documented?
Tags (2)
Yuri
  Please use definitions in the i.MX28 OBDS.
On-Board Diagnostic Suit for the i.MX28
Summary Page :
i.MX280 Processors|Low-Power|NXP
Yuri
FredrikMoller
Thanks for the answer.
I downloaded the OBDS and searched for "USB_ANALOG" in the folder "/201040_mx28_evk_release/src". No hit unfortunately.
Yuri
From the team :
Why you need this base address ?
Do you meet any coding issue to use this base address?
Please let me know the details about Your project.
You may create request as following :
1)Please open www.nxp.com
2)On the top level menu, select Support > Sales and Support (http://www.nxp.com/support/sales-and-support:SUPPORTHOME).
3)On the bottom of the page, select Hardware & Software.
4)Register with your business email to access the technical NXP online support.
5)A verification email will be sent to your account. Click the embedded link to verify your access.
6)On the NXP online support page, select Contact Support from the top menu and click “submit a new case” to start the process.
Yuri.
