Uboot and NK(wec): Display is not getting
rizwan_s
Hi All,
Am using Imx 6Q sabre SDP board.i need load to WEC7 using Uboot. When i try to use Display is not getting.
DDIPU is not getting called.
Is there any setting missing regarding to display when i use uboot?
Rizwan Syed
jamesbone
I understand,  please check the link.  to find where to modify the IVT table in order to UBOOT to have the proper link to start.
rizwan_s
Hi James
IVT comes in bootloader  right. But for me drivers are getting loaded SD,USB and display is not coming.
Rizwan Syed
jamesbone
Hello Rizwan,
NXP does not support WEC but I think you are not using the correct IVT Table in Eboot to download from Uboot  you can take a look at :
Vinoth's Windows Embedded & IoT Experiences: Windows Embedded Compact 2013 – Understanding STARTUPTE...
rizwan_s
Hi james
Actually am not using Eboot. I am using Uboot and NK through fatload and go commands.
Rizwan Syed
