mtd-utils-201006.tar.bz2
qiaoweibiao
Processing: u-boot-tools
Processing: mtd-utils
Build path taken because: no prebuilt rpm,
Testing network connectivity
OK GPP:
Try mtd-utils-201006.tar.bz2.md5 from the GPP
http://bitshrine.org/gpp/mtd-utils-201006.tar.bz2.md5:
17:11:10 ERROR 404: Not Found.
Try mtd-utils-201006.tar.bz2 from the GPP
http://bitshrine.org/gpp/mtd-utils-201006.tar.bz2:
17:11:11 ERROR 404: Not Found.
Can't get: mtd-utils-201006.tar.bz2 at ./ltib line 802.
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
Started: Thu Jan 21 17:11:07 2016
Ended:   Thu Jan 21 17:11:11 2016
Elapsed: 4 seconds
These packages failed to build:
mtd-utils
Build Failed
who can help me to fix it ??
Thanks a lot.
Labels (2)
Hi hiao
below attached mtd-utils file, please put it to /opt/freescale/pkgs
directory.
Hi hiao
directory.
qiaoweibiao
frist thanks for your right answer.
now i also need the
mtd-utils-201006-4K-218-224-support.patch
can you give me ?
thanks a lot .
for the log:
OK GPP:
Try mtd-utils-201006-4K-218-224-support.patch.md5 from the GPP
http://bitshrine.org/gpp/mtd-utils-201006-4K-218-224-support.patch.md5:
18:41:55 ERROR 404: Not Found.
Try mtd-utils-201006-4K-218-224-support.patch from the GPP
http://bitshrine.org/gpp/mtd-utils-201006-4K-218-224-support.patch:
Can't get: mtd-utils-201006-4K-218-224-support.patch at ./ltib line 802.
traceback:
   main:554
Started: Thu Jan 21 18:41:52 2016
Ended:   Thu Jan 21 18:41:55 2016
Elapsed: 3 seconds
mtd-utils
Build Failed
please find file attached
~igor
qiaoweibiao
gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1.i386.rpm
now i need this file ,
there is always 404 not find .
How can I  find thems by other means?
Thanks a lot .
