Can someone please verify the port pins PT0 - PT7 all have internal clamping diodes to VSSX and VDDX?
I understand that this is stated in Table A-1 "Absolute Maximum Ratings" of the MC9S12G Family Reference Manual. However, I need to be absolutely sure that these diodes are in place. Please confirm.
Derrick
Solved! Go to Solution.
Hi Derrick,
Yes, the port pins PT0 - PT7 all have internal clamping diodes to VSSX and VDDX.
I just double check it on our TWR-S12G128 board (by 5.5KOhm pull resistor to +/-12V)
I hope it helps you.
RadekS
Hi Derrick,
RadekS
