Flash programmer for 56F8xx stand alone
giamma
Qualcuno sa suggerirmi come programmare la flash dei DSP serie 56F8xx in Windows 7 con un software che non sia CodeWarrior
TICS_Fiona
Hello Giovanni
The programming tools for 56F80x we supply include:
1)  CodeWarrior for DSP56800/E
2)  Flash_over_jtag
3)  Bootlader.
1) and 2) are both using JTAG interface. 3) uses SCI or CAN interface.
flash_over_jtag can only support parallel connection, it does not support USB interface. It does not support Windows 7 either.  I attached this tool.
Best Regards
Fiona Kuang
Technical Information & Commercial Support
TICS_Fiona
Hello Giovanni
2)  Flash_over_jtag
3)  Bootlader.
Best Regards
Fiona Kuang
trytohelp
Translate with google:
    Suggest someone knows how to program the flash of the DSP series 56F8xx in Windows 7 with software that is not CodeWarrior
I think the answer will depend of the interface used ?
I've found some information on the web:
     DSP56F801|Digital Signal Controller|NXP
Interesting doc at:
     http://cache.nxp.com/files/product/doc/AN1926.pdf
Pascal
NXP Technical Support
