I found i.MX6 can support up to 720p 4ch cameras.
iMX6DQ MAX9286 MIPI CSI2 720P camera surround view solution for Linux BSP
If there are 1080p 30fps 4ch cameras, is it possible to capture image data using SABRE2-AI board and AVB?
Best regards.
Solved! Go to Solution.
I am afraid the configuration of 4 channels 1080p 30 fps cannot be
processed via Ethernet of i.MX6 because of performance lack, since
~237 Mbytes /sec throughput is required for raw data. If encode the
images, VPU has no enough performance for it too.
Yuri
Yuri
