Regarding power consumption of KEA128
jashanm
Hi all,
          I am working with KEA128 in one of my application, I am supposed to calculate the power consumed by it. I am working on UART, CAN, I2C, SPI, GPIO, FTM & internal clock. So how do i calculate the approximate power consumed by my MCU ?
santiago_gonzal
If you have a look at the datasheet you will find the information you need. You need to add the RUN power consumption and the adders of each peripheral.
Santiago
