value is behaving randomly
Question asked by rahul krishna on Jan 18, 2016
Latest reply on Jan 27, 2016 by lama
I am facing a very tricky scenario. I am using s21x i have found a code as follows
the definition as in file1.c
unsigned char value[12];
and the declaration as follows
extern unsigned char value[11];
clearly both do not match and it is wrong and i am facing an issue where the value modified in file2.c as
value[11] = some value; is behaving randomly that is it goes to some unexpected value. specifically value[11] is behaving randomly. Since the issue is difficult to reproduce can i assume that above mismatch can be a problem. How the code will behave in above cases. Please help.
