We bought the license for the CodeWarrior Specialist Tool Pack - Node locked version with the p/n CWA-LS-SPLST-NL, plus the USB Dongle CWH-DONGLE.
I made the license registration as per disk serial number instead of FLEX-ID, in order to use the usb-dongle. How can I roll-back the licence in order to make a right FLEX-ID registration?
Registered data is 01/12/2016 and registered to Fabio Fontana.
Thanks.
Fabio.
Hi Fabio,
You've generated the license file under DiskID and you want to lock it on USBDongleID.
You need to return the license and re-generate the license file.
Licensing and Registration FAQ|NXP
There are some others docs on community:
How to rehost CodeWarrior suite license
Hope this will help
Pascal
NXP Technical Support
