CW licenses re-host problem
matteomantica
Dear All,
I need to re-host my CW perpetual floating licences to a new server. I cannot do it myself because I cannot see my licenses in the relative page. See the following screen:
I the Order History page everything is correct and my orders are presents (see following screen)
How can I proceed?
Best Regards
Matteo
trytohelp
Hi Matteo,
You need to select the registration number via the Order History.
Then you can display all license file associated to a registration.
You can refer to the FAQs:
     Licensing and Registration FAQ|NXP
Else there are some info on community:
     How to rehost CodeWarrior suite license
     Cannot Re-host a license - License Lists is empty (valid to generate a license file associated to a...
Now if you're using a classic tool, you could have some problem after rehost.
In this case, to avoid problem we can re-encrypt the license.
Pascal
NXP Technical Support
trytohelp
Hi Matteo,
Pascal
