MPC5604E - Viewing AVB videostream
thiesteichmann
Hello everyone,
i have another question. I've tried viewing the videostream with the VLCplayer, but it has a huge delay. So i tried viewing it with openCV, but the lower half of the video is stuttering (upper half is running smoothly). So i figured trying AVB would be a good idea. Does anyone know a way/tool to view the AVB videostream? Kuan Hung Lin can you help me with this, as you did with my problem last week?
Thies
Tags (2)
kentlin
Hi Thies,
you can reduce the cashing of VLC player to have better reponse.
I didn't try the AVB firmware either.
Kent
thiesteichmann
Thanks, vlc works better this way. Additionally i now use Technica Engineering's Ethernet Video Analyzer software, which is capable of displaying the AVB videostream. Next problem is changing the ip address, which i will describe in the appropriate thread: MPC5604E - Data via BroadR-Reach
rsm911
Could you or someone supply the required *.sdp file contents for receiving H.264 over AVB stream and displaying in VLC ?   I have looked elsewhere on the web without success, even on the VLC website.   Thanks in advance.
