Change root parameters in recipe
nicolassalmin
Dear all,
It's my first post and i'm new with Yocto project.
So, I have some trouble and I hope that somebody can help me ...
I would like to change root group in order to use an usb camera. (root need to be in plugdev group). Some examples are available here​ and i have used them to write my recipe :
SUMMARY = "Add root user to plugdev group"
DESCRIPTION = "This recipe add root user to plugdev group (for  camera support)"
inherit extrausers
# Add root user to plugdev group
EXTRA_USERS_PARAMS = "\
     usermod -a -G plugdev root; \
There is no error during the build but, on the target root is not in plugdev group
Thanks for your help
Have a good day,
Nicolas
gusarambula
Hello Nicolas SALMIN,
Have you tried either adding these to the image recipe itself or to the local.conf file (using INHERIT += "extrausers" instead of just inherit in lowercase)? I think the problem might be that these settings work on a global or image level.
Let us know of your findings!
gusarambula
nicolassalmin
Hello gusarambula,
Thank you for all your advice it's works !
For information i have changed root user group/home directory by adding these to the image recipe as you told. It works also with a bash script in init directory.
Thanks again !
