How do I perform boundary scan using CodeWarrior TAP for MPC5200?
Does it have a fix programming code for it?
Which codewarrior software should I install in order to perform boundary scan?
Thank you.
Evan
Solved! Go to Solution.
Hello Evan
We do not have recommendation for using boundary scan JTAG mode for final testing of hardware.
You can find the BSDL file from:
http://www.bsdl.info/list.htm?m=15
The BSDL file for MPC5200 is on page 4.
For example, please have a look at:
Hope this will help you.
Best Regards
Fiona Kuang
Technical Information & Commercial Support
Hello Evan
Best Regards
Fiona Kuang
