LS2085ARDB and OpenDataPlane
Question asked by nicolaskury on Jan 11, 2016
Latest reply on Jan 19, 2016 by nicolaskury
I have received a LS2085ARDB board and I would like to try OpenDataPlane. I start with the default (pre-installed) image and it seems that OpenDataPlane is already installed. In usr/nadk/nadk-static/bin there are some applications such odp_pktio and odp_l2fwd.
But I have some errors
root@ls2085ardb:/usr/nadk/nadk-static/bin# ./odp_generator
odp_init.c:211:odp_nadk_init_global():Enviroment varialble DPRC_NAME is not setodp_init.c:271:odp_init_global():ODP nadk init failed.
odp_generator.c:573:main():Error: ODP global init failed.
odp_init.c:124:odp_finish():odp_finish
Should I also run the  script ./usr/nadk/nadk-static/bin/bind_dprc.sh ?
I didn't find the documentation. My ethernet interface in front the board are also not available in Linux, is it normal ?
Thank you!
