Is it possible to use MPXV7025DP sensor from 3.3V power supply?
Question asked by Bela Mihalik on Jan 11, 2016
Latest reply on Jan 11, 2016 by David Diaz Marin
I made a small PCB with MPXV7025DP pressure sensor, and I connected its power pin to 3.3V. It seems working, however the device's data sheet says its operating range is between 4.75-5.25V. Can I use this sensor from 3.3V? - or it gives absolutely wrong and nonlinear result.
