t2081 u-boot compile
Question asked by gyosun shim on Jan 11, 2016
Latest reply on Jan 11, 2016 by Pavel Chubakov
Hi All,
I made a note similar to the T2081 board T2080RDB.
There are several questions in relation to compile u boot.
1. In u-boot code I do not know what to do I want to compile by selecting CONFIG_PPC_T2081.
Can you tell me how? Please detail.
2. "CPU up timeout. CPU up mask is 7 should be f" message is output when you are booting. If this message is output there will be a problem with the boot.
3. Thank you for what you should be modified when changing from T2080 to T2081 advice.
Best Regard,
gyosun.
